AnyTone TERMN-8R 2 Tone Decode
cheld18
Pleasant Plains, IL
I was just curious if anybody was successful in using the 2 tone decode feature on the radio. I used the guide on Miklor to help set up some 2 tone decoding, but have been unsuccessful in getting it to work. Not sure if it's a lack of programming something or some other problem.
Thanks in advance,
Craig
K3NXU
Shrewsbury, PA
Thanks in advance,
Craig
I set mine up using: Anytone TERMN-8R FAQ - Miklor
To test, I set my handhelds to a simplex frequency, and set the TERMN-8R to the sample shown.
http://www.genave.com/audio/two-tone-paging-378hz-422hz-1sec-3sec.wav
Then held one radio close to the speaker to transmit the tones to my TERMN-8R.
It opened up the squelch just as it should.
Once the test works, adjust the tones, timing, to your local EMS.
I have a TERMN-8R and OBLTR-8R, and it works on both.
cheld18
Pleasant Plains, IL
Finally got it to work. I was using Motorola tone values and I had to adjust them by a couple of decimal digits to get the radio to decode and alert. Thanks all for the help.
Voyager
That's not right. The tone frequencies should not change depending on which radio is used.
