TK-7180 F1FF
Hiding in a coffee shop.
v1.22 is the latest and is the only one available on the dealer tools page. Unless you can find someone that has an archived copy, you'll likely only be able to get the latest version from a dealer.
It should, being able to select low or high power is a standard advertised feature of the radio.
If you meant actually being able to set the specific output level for the low and high settings, that isn't part of the programming, it's part of the service mode.
WatnNY
Knoxville, TN
In the software I have there is no option for high/low transmit, my ONLY complaint with the radio/software.
Mike
kayn1n32008
ØÆSØ
Sector 001
Mike
Odd I was able to program high and low power channels in my TK-8180... You need to open the channel edit window... It is there... I promise. The only thing I would change on the x180 series is the ability to program a button to toggle low power. Great radios.. Love my TK -8180.
WatnNY
Knoxville, TN
That's what I meant, Kayn1n32008 - you can't program a button to do high/low power!
Mike
kayn1n32008
ØÆSØ
Sector 001
The software does not allow the ability to program a button to select low power. You mist program channels twice, one high power one low power. Only the portables allow a button to be programmed for low power.
WatnNY
Knoxville, TN
That's what I was thinking kayn1, programming two channels - that must be why there's 512 channels!!!
Mike
