I think I understand now. Not sure. Couldn't make it work on 8.1 because it locks up on the driver install. Had created the data and scanlists/play lists in 8.1. Never got them to the scanner. Now fully installed on 7 but the file work is all over in 8.1.
You should be able to just copy the CDAT folder/files from old computer to new at same location and then restart iScan in 7 and see your files. Then hook up the radio, download to radio and good to go. Hopefully I interpreted the issue correctly.
536/996P2/HP1e/HP2e/996XT/
396XT/PSR800/PRO668/PRO652
Mark, you got the problem right on the money. Once Mikey60 told me where to look and what folder needed to be moved I was able to get the information over to the windows 7 computer and now things are working well.
I am confused. First post says your going from windows 8.1 to 7
Now you cant connect on your windows 8 machine? Which way are you trying to go?
I downloaded the software onto my windows 8.1 before my radio arrived in the mail. I put together the scanner the way I wanted and when I attached the radio the driver would not load. When I installed on the windows 7 machine everything worked well. I just needed to get the information on what file or folder that needed to be moved.
On your 8.1 machine have you tried rebooting 8.1 in the "disable signed driver verification mode" - I am running iscan on 8.1 and once I disabled driver verification it allowed iscan to recognize the scanner and I have no problems communicating with the scanner
Yes, I went to the Whistler Group site and printed out the instructions. When I get to step 7
1.) When you are signed in to Windows 8 / 8.1 as Administrator connect the WS1080. It will then attempt to load the driver and appear to succeed but the driver will not be working at that point. Even though the serial driver is not correctly installed you will still see the scanner’s MicroSD card.
2.) Copy the INF folder from the WS1080 to a folder on your computer
3.) In Windows 8.0 While on the start load the Charms Bar by pointing the mouse at the upper right hand corner of the screen.
4.) Select Power and hit restart while holding down the Shift key.
5.) A selection of Troubleshooting options will come up, select the Troubleshoot option
6.) Another page will appear, select Advanced Options.
7.) The next page will display several repair options, Select the Startup Settings to change the behavior of Windows Startup and then click restart on the next page.
the computer locks up and I have to enter a code from Microsoft to unlock the computer. I also followed the instructions to put the computer in admin mode prior to following the instructions from Whistler. I also attempted with out placing the computer in admin mode and nothing will allow me to to install the unsigned driver. This will be the next issue to tackle.
You all are going about this the hard way. According to the OP, he created the new setup on his 8.1 machine, therefore, he obviously already has Iscan running on that machine. The easiest way to transfer the new setup to his scanner, is to power off his scanner, and I personally also remove the batteries as well, just to be sure, then remove the SD card and put the card in the 8.1 machine. Open Iscan and write the new setup to the card. Eject the card when the write is done and reinstall card in the scanner. Reinsert the batteries and enjoy.
Yes this would be the easiest way, but I did not know what files or folders needed to be moved, as that was part of my original question. After I moved the folders over to the windows 7 machine I did the smack to the forehead and thought I could have just replaced the CDAT and CDAT_VS.XX folders onto the SD card. Lets face it tunnel vision gets us sometimes and we miss the obvious, that is why groups such as Radioreference are so important.
Again thank you to everyone that gave suggestions, input and assistance, as I could not have done it without you.
