AirMed
jackj
NW Ohio
Does anyone know the frequencies used by air ambulances for air-to-ground communications? They are called AirMed 1 and AirMed 2 in NW Ohio, I believe they are simplex and I've been told that they are in the 800 MHz band. I have search this site as well as some others but I haven't found any info on them.
Jack
N8BSR
radioscan
Radio Sensei
Southern Ohio
They used to be two of the pre-rebanded NPSPAC interop frequencies 866.5125 and 867.5125. I think the use of those were discontinued after rebanding. Now they can use any of the 8TAC## frequencies. 851.0125, 851.5125 etc.
Sent from my GT-N8013 using Tapatalk
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
This is correct.
air helicopter
I am constantly amazed at the knowledge some people have on here!!!!!!!!!!!!!Things I never even knew existed yet someone out here knows the answer. Heck, this site is better than GOOGLE!!!! LOL
jackj
NW Ohio
Thank you, gentlemen. Stephen, you are right about the knowledge enshrined on this web site.
parma,ohio
AIRMED-1,AIRMED-2
i have these that came from a radio code plug this maybe what your looking for?
AIRMED-1 852.0125 DIGITAL NAC-293
AIRMED-2 853.0125 DIGITAL NAC-293
Jack N8BSR PLEASE let me know if what i found works.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Those look like something someone set up for local use. The nationwide 8CALL/8TAC frequencies (the two you have listed are 8TAC92 and 8TAC94) are supposed to be used analog with PL 156.7 so it appears someone is freelancing.
Since rebanding, the statewide SOP calls for use of the standard 8CALL/8TAC frequencies, as everyone has them and the names, frequencies and tones are standardized.
jackj
NW Ohio
AirMed 1&2
David,
Delta had two rescues shortly before noon Saturday, they requested copters for both. LifeFlight was called on the first one and Promedica's copter got the second. I heard both on 852.0125 MHz (AirMed-1), both were on analog with a tone squelch of 156.7 Hz. I've set the scanner for "Auto" so it should pickup both analog and digital modulation.
Jack
N8BSR
RakkFO
Central ohio
I know I have had issues dealing with making contact via radio going into facilities in the Toledo area. I was advised we could use one of the Med Channels from National Interop plan but they used odd PL tones. Defeats the concept of Interop.
