I have a BCD 436 HP, and am putting on favorites using Sentinel. Do I have to put the Sites on there as well or can I leave them off to shorten my list.
Yes , but you only need the appropriate ones, closest, strongest, the ones you want to monitor, etc. Sites contain the frequencies and structure - all the rest is just the talk groups.
It may be easier re-creating your Favorites List file if it is small.
If not you could go to the database part of Sentinel, select the systems you wish and append them to the existing Favorites List. You may have duplicate departments which can be deleted.
I can't see why it would be an issue if you are creating the Favorites List by grabbing the stuff in the full database. It all should be appended to the scanner.
Now if you are manually adding sites, that could be an issue, but the need to do that would be rare.
