parnass
AJ9S
You hear transmissions from what sounds like a retail store operation. Which store are you hearing? It can be difficult to identify the store you hear when there are several retail stores in the same general vicinity.
One of the most common things you hear when monitoring stores is a staffer describing an item and referring its stock number, often when asking for a "price check." Stock numbers are usually unique to the retailers.
Search the web using the stock number and you can usually determine the identity of the store.
