The Pro95's been flawless for 10+ years. It's attached to a headboard so I never look at the display when turning it on. Yesterday I decided to connect it to a dipole antenna and noticed the display issue. Having adjusted the contrast level to its highest mode the display is very feint. I disassembled the unit looking for something that might be obvious but found nothing. I removed the 3 screws that secure the pcb/lcd screen and didn't notice anything extraordinary. I used contact cleaner on the ac-adapter pin and pins that have direct connections. Don't know if this helped but when I turned it on it was slightly more visible. Initially before disassembling vertical bars were present (instead of text) during transmission.
Where it stands now is that I see a ribbon at the top of the LED plate. The other issue is that the battery holder does not work. It works fine with the Pro106.
Any and all help is appreciated; in advance thanks!
