Motorola Maxtrac
kk4fli
Hayesville, NC
I have a Motorola Maxtrac 32 channel that I can't get it to scan the channels. The model number is D43MJA7JA5AK. When I bought the radio it only had one channel programmed in it. I programmed 23 channels in the radio, but when I press and hold the scan button on the face for 2 or 3 seconds it will not let me program the channels I want to scan. I did program a scan list with the software, but it still will not scan. Anybody have any idea's what I can do?
EZlistener
Tennessee
Is your microphone hang-up grounded? If not, I believe there is a setting in the RSS which will allow scanning without the microphone being "on-hook."
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The mic has to be hung up on a metal mic hanger for scan to work. If you don't have a mic on the radio, then you need a little jumper assembly that shorts out two pins in the mic jack on the front of the radio. Pin #3 (hook) needs to be shorted to Pin #4 (ground.) in the mic connector.
There are several previous threads on the subject.
http://forums.radioreference.com/mo...-do-i-use-scan.html?highlight=motorola+jumper
I used to have some but gave them away over the years. They can be purchased from a very reliable seller on ebay called mre1032. If he does not have a current listing for them, contact him. He's great to work with.
Not in the older radios. The jumper is needed, either by the mic itself or the shorting assembly.
kk4fli
Hayesville, NC
Yes, the microphone is hanged up. I changed the setting with the software where it didn't need to be hung up, but changed it back.
rescue161
KE4FHH
Hubert, NC
One of mine was doing the exact same thing. I traced it to a cold solder joint on a surface mount resistor. Re-flowed solder and now it works like a charm.
ramal121
Lots and lots of watts
Calif Whine Country
If the radio is in scan and the mic is on hook, you will only have horizontal bar(s) in the display. When the mic is off hook the display will alternate between the horizontal bars and the channel number. Easy way to tell what state the mic is in.
If you have constant horizontal bars then your scan problem lays in programming.
rescue161
KE4FHH
Hubert, NC
On mine, there was an open between the 5V source that was feeding R880 and R880. Upon pressing my meter probe on R880, I got the correct readings, but when I lifted the meter leads, the open appeared again. Pressing on the 5V side of R880 resulted in the radios scanning (I had the mic grounded). Re-flowed solder to both sides of R880 and it now works like a champ.
ramal121
Calif Whine Country
Glad you found your problem but I'd say that's kinda rare. Microphone failures are much more common. Bad cords or the HUB contacts fail in the mic, especially in the white compact ones that cannot be opened to repair.
