XPR-6550 CQII encode
kf5ena
I've googled and searched the forums and haven't found anything to answer my sort of question so pardon me if I overlooked something. I'm trying to set up a pair of 6550's to send out CQII to page out or fire dept. It works through the menu but I can't seem to figure out how to set it up on a long press button. I don't have a problem with this but a couple of our guys aren't real radio savvy and will probably have a hard time remembering how to navigate the menu. As far as I can tell it can't be done but I'm hoping one of you can shed a little light on my ignorance. Thanks in advance
cmdrwill
So Cali
You are probably looking for the Signaling settings, Quick Call II.
Not sure on that model if it will transmit the QCII.
kf5ena
It transmits the QCII just fine, but I have to go through the menu to do it. I was in the section for button selection but couldn't find a select call or call alert option. All of what i saw was either TRBO or capacity plus. Couldn't find any options for analog. I'll give it a fresh look when I get home.
And yes, I do have a display model w/ full keypad.
kf5ena
Well I looked several different times but no luck. on the upside I was able to train my Captain on how to run it through the menu so all is well. Thanks for the input guys!
