Tk-3180 Temporary Priority Channel
Colton25
I see in the scan information that you can configure the radio to temporaraly add or delete a channels priority setting manually on the radio. I have tried configuring the radio all ways that i can think but i still can't get what i'm looking for. Can anyone help me out?
ramal121
Lots and lots of watts
Calif Whine Country
Well just looking at your screen, you have to set your priority 1 type (and priority 2 if you want it) first and then you are able to check/uncheck the temporary delete boxes that will allow this function.
To use just press your add/delete button whenever scan lands on a priority channel.
Or are you wanting to change the priority channel on the fly? Then use "operator selectable" as your type. Press and hold the scan button to enter the configuration for this.
Colton25
I tried the OSP but when I hold the scan button OST just appears on the screen and I don't know what to do from that point. I just want to be able to turn the priority on and off and be able to change which channel is the priority of possible.
kayn1n32008
ØÆSØ
Sector 001
Then you need to configure your buttons to support both Scan and Add/Delete. If you are getting OST when you press a button, the button settings are not correct.
Sent from my iPad using Tapatalk
Colton25
I have both scan and add/delete programmed into the radio, in the help it says to press both but it does nothing...
mikepdx
Corbett, OR USA
I wouldn't think that <help> is relevant if those custom programmable
keys have been reprogrammed for other functions.
Read the radio.
Look in your software.
Verify what the function keys are currently programmed to do.
Colton25
It's not saying OST it's saying OSP as in "operator selectable priority", and once it says that if i hit any other button the OSP disappears.
Colton25
This is how i have it programmed.
Read the radio.
kayn1n32008
ØÆSØ
Sector 001
Edit: just saw your response about OST.
OSP is a feature I do not use, so I am going to bow out. Hope you get it working.
Colton25
Yes i have programmed the radio, i made a typo in a earlier post it does not say OST it says OSP as in "operator selectable priority".
Silly question, but you have programmed these settings into the radio right? The changes you made MUST be written to the radio before they take effect..
OST should NOT come up when you push ANY of the buttons.
Colton25
Ok i figured it out, once you get to the channel that you want to be the priority hold down the scan button for 2 seconds, the OSP will appear then you press the C button and you can toggle between the priority being on or off for that channel. This is an awesome feature that will really benefit me with both my 2180 and 3180, Kenwood is always amazing me with all the simple user friendly features they have. Thanks again for the help.
