Look for something like a switching power supply, 12 volts, 15 amps continuous.
If you plan on adding more equipment later on, consider purchasing a higher capacity power supply.
Some might balk at switching power supplies for communications use. A long time ago they were noisy and could cause a lot of issues, not so anymore. Used to be "good" ones were big heavy transformer based power supplies. They weighed a ton and generated a lot of heat. I'd avoid that unless you own stock in the utility company and have someone with a strong back to move it around.
Also, depending on what your intended use it, you -might- want to consider a power supply with a "battery revert" connection. These will allow you to connect a 12 volt gel-cell type battery. The power supply will keep it charged, and if the power fails, all your gear will still run.
Modern LMR radio systems almost all use switching power supplies. Get a good quality name brand model and you'll be fine.
