emegency mode reset help
kennedy-r
Massapequa Fire District
Is there any way on an xts 2500 to have the emergency bursts continue after the radio is transmitted on? Our radios after the emergency is set send a combo of polite and impolite emergencies until someone talks on that radio. We would like them to restart after the voice transmission of a mayday is this possible?
krokus
Southeastern Michigan
Emergency mode is reset by holding the emergency button down, for a few seconds.
Beyond that, what you are saying is unclear.
Sent via Tapatalk
kennedy-r
What I'm trying to say is after the emergency is initiated if a user transmits trying to get a message across and then Dekeys the portable emergency does not continue transmitting Mdc emergency bursts
jhooten
Paige, Republic of Texas
If I may ask why do you want this? The problem I see is it would continue to tie up the channel preventing a second unit with an emergency from being able to trigger an alarm.
CommJunkie
FM19gt
Generally speaking, if you can reach the radio to transmit, you don't need it to alert the emergency ID. The EID's are to alert the dispatchers of a problem. I don't believe any radios have pinpoint GPS with the EID so having it continue to go off when you can reach the radio to talk is pointless.
kennedy-r
Morning,
Yes I understand this could tie up the channel and does seem counterproductive to me but this is what they seem to want here where I work. We use emergency mode on a simplex channel on the scene to alert the safety officers and incident commanders of the issue. There will be extensive testing before anything goes in service its really just a question of is this possible...thanks for the help guys
RKG
Boston, MA
As I recall, the CPS offers a number of options regarding the emergency MDC message, which are explained in the help files. Unfortunately, I'm not near my programming computers.
The basic concept, though, is the the initiating subscriber continues to send the emergency word until the sooner of (1) receipt of an acknowledgement message from the dispatch console or (2) expiration of the retry counter. I am surprised to hear that a simple key of the initiator terminates an unacknowledged, unexpired retry, since that behavior would obviate the need for a cancelation method.
So far as I am aware, there is no way to program a subscriber to send the acknowledgement; that function is built into the Stat-Alert modem on a Motorola console or achieved via a Cimarron MDC controller on a Zetron console. Again, the construct of the MDC emergency function is that it is received by dispatch, after which dispatch handles alerting and coordinating field forces.
tbendick
Nyc
Are you using mdc or tps?
tbendick
Nyc
we are actually using both mdc signalling and tps for a beacon tone to find the down member
can you send me a codeplug to compare? Any reason why you wouldn't use tps over mdc?
I am pretty sure our radios keeping going until it's manually reset. I can try a radio in the am and see if there is a difference when using mdc.
