Xpr 7550 antenna
jonvenusti
Banned
Hello, Im going to be receiving my XPR-7550 tomorrow. I am aware the antenna connector is proprietary so you cant use an external antenna. However I was thinking, would it be possible to buy another antenna and hack it up to get to the wire inside and then attach a PL-239 SO 259 connector to attach an external antenna. Thanks, Jon
N4KVE
PALM BEACH, FLORIDA
The Canadian IS version comes with a SMA connector. Should have ordered that one. Possible that connector can be ordered, & retrofitted into your radio.
Project25_MASTR
Millennial Graying OBT Guy
Texas
For some reason I'm thinking they went back to the same connector used on the MX series. Must've not looked well enough.
clbsquared
Isle of Wight County
While it may get you out of a bind, I would not recommend it. That video was made to illustrate a poor design on Motorola's part.
Sent from my HTC One A9 using Tapatalk
Firebuff880
Boynton Beach, FL
In North America the radio you want is the XPR-7550e HK2080A --- It's the Call Box RF Kit, and uses the SMA type Antenna connector. First availability is today - 2/20/2017. So you might not find many in the channel yet and I am not clear what the Display or Button situation is on this unit since it's intended to be a Data Modem more than a radio.
mrwhitee
I already have the 7550 so I dont want to buy another just so I can have what it should have already come with. Ill buy another brand before I do that. I wonder if anyone has tried to get a shop to covert one of these. Seems like it wouldnt be that hard but I dont know.
mrwhitee
No big deal. It looks like we have some dual band radios coming so ill probably get one of those and keep my 7550 as is.
