I frequently monitor AZ DPS West and realize that the mobiles seem to switch between two repeaters that are transmitting on 460.300 MHz. FCC records indicate that two 460.30 repeaters exist at slightly different positions on South Mtn.
Can anyone explain how DPS decides which 460.30 MHz repeater to transmit from? Does DPS operate a voting system which votes on the mobile signal strength of the mobile transmissions and then decides which repeater to activate?
Aware that the mobiles can operate in the talk around mode on 460.300 Mhz.
Curious here,
Curious here,
