my pole is 16' tall. how long should my coax be to get the best results? i have only had mobile units up until now, this is my first base station.
Not to sound flippant, but the cable should be exactly as long as it needs to be to get from the antenna to your radio, and maybe a bit of slack.
There is no magic length for coax in normal cases. Ideally you want to use the least amount possible to reduce feed line losses.
Which cable you use is a more important question. Length affects losses, so if you have a long run, you may need to use a higher grade cable than if the run was shorter.
Higher frequencies suffer from higher attenuation in the cable, so if you are using 700/800MHz, you may need to use a higher grade cable than if you were using it with lower frequencies.
