Northern Arizona Consoladated Fire District #1 New Fewquency
FLANO
AZ DB Administrator
SE of Tucson, AZ
I took a look at the FCC frequency database and it has four callsigns for them. One is input to the Meds channel, which all FD/EMS have or should have.
The other three show there are a couple of possibilities. Try these out:
154.355 - should be a Base/Mobile frequency
153.89 - should be a Base/Mobile frequency
453.625 - should be a Repeater frequency
I'll update the callsigns for the frequencies in the database.
You could also try those and the other known frequencies without pre-programming the PL's to see if they may have changed them up, if you are not hearing anything.
Of course, if any of the above is true, please submit an update to the database.
Thanks,
KA7MBQ
Dolan Springs AZ
At the fire board meeting the chief said they needed to post their new licenses.. They were using a paging frequency, and the audio went bad a couple weeks ago. My guess is they were putting new freqs in the good repeater.
Jay
Arizona
NACFD uses the KFD alarm channel 155.0550. NACFD units are 3xx.
GVFD - 100's
KFD - 200's
NACFD - 300's
LMRFD - 400's
PPFD - 500's
Each department still retains use of their prior tactical frequencies, but are all dispatched on the same alarm channel. This has been in effect for about three years now.
