Audio 3 server
mckinscan
Spartanburg sc
same with me my keep going up and down
my scancast logs show
04-May-2015 10:26:46 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
04-May-2015 10:26:46 Disconnect details follow (for debugging if necessary):
Message: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
Source: System
TargetSite: Void Write(Byte[], Int32, Int32)
StackTrace: at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at ScannerCast.ScannerCast.PushClientThread()
--Message: An established connection was aborted by the software in your host machine
Source: System
TargetSite: Int32 Send(Byte[], Int32, Int32, System.Net.Sockets.SocketFlags)
StackTrace: at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Socket error: 10053
04-May-2015 10:27:06 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:27:37 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:28:27 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:29:58 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:31:28 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:32:59 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:34:29 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:36:00 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:37:30 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:39:08 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:40:39 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:42:10 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04-May-2015 10:43:31 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
04-May-2015 10:44:52 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
04-May-2015 10:46:13 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
04-May-2015 10:47:34 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
04-May-2015 10:48:55 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
04-May-2015 10:50:24 Connection complete to RR server audio3.radioreference.com/532571714
04-May-2015 10:57:05 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
04-May-2015 10:57:05 Disconnect details follow (for debugging if necessary):
Source: System
Source: System
Socket error: 10053
04-May-2015 10:57:17 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
04-May-2015 10:57:37 Connection complete to RR server audio3.radioreference.com/532571714
04-May-2015 10:59:41 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
04-May-2015 10:59:41 Disconnect details follow (for debugging if necessary):
Source: System
Source: System
Socket error: 10053
04-May-2015 11:00:00 Failed to get reply from Icecast server audio3.radioreference.com/532571714: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
04-May-2015 11:00:21 Connection complete to RR server audio3.radioreference.com/532571714
04-May-2015 11:02:04 Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
04-May-2015 11:02:04 Disconnect details follow (for debugging if necessary):
Source: System
Source: System
Socket error: 10053
04-May-2015 11:02:18 Connection complete to RR server audio3.radioreference.com/532571714
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
It crashed with a hardware problem - we've moved it over to a spare standby server. You may need to restart your broadcast since we had to update the DNS entries for the server.
johnmac
Westminster, Ma
I am not able to re-start my feed either.
Shut down RadioFeed and restarted, still no luck
Edit, my other two feeds on Audio1 are working fine
DXstuboy
Blaine, MN
Same here: Sheridan County EMS/FD - Wyoming on audio3. Keep getting the same error. Have hit retry numerous times.
blantonl
Founder and CEO
Staff member
Super Moderator
Some other things you can do are:
1) Reboot the computer - that will help flush any cached DNS entries on your computer
2) Reboot your router / modem - many ISP modems will cache DNS entries as well.
THanks,
richtidd
San Mateo, Ca
Since we replaced the server, the stream to IP address was changed to a new one.
For those feed owners who use an IP address vs the server name for the stream to, please send us a help request via the HELP tab of your feed page to ask us for the new IP address.
fredva
Virginia/West Virginia
My feed on audio3 has distorted audio and has frequent breaks and restarts. Based in part on times given by the dispatchers, I'm suspecting that there is little to no audio buffering taking place as would be normal. I'm assuming for now that this is part of the recovery process.
The good news is that it's not going completely offline as it was yesterday.
KD0TAZ
Kansas
My feed has been bouncing up and down for the past several hours.. Are there more issues?
