Bug found??
In v1.051 when you close the 'Channel Activity' window, it will close.
In v1.071 when you close the 'Channel Activity' window, the program closes down.
Bug #2
1) When I start the program, it will not show NXDN Alias on the voice channels in the Event Window
2) When I look at the control channel, it will see the alias that is transmitted on the control channel in the Event Window.
3) When I go back to voice channels, now alias's are showing in the Event Window.
Now most of the NXDN traffic i have is Encrypted and the above steps corrects the alias
until an un-encrypted talkgroup come on and then the 'Event Window' stops showing 'alias' again just a few transmissions later.
Have to repeat steps 1-3 to make it start showing up once more.
No NEXEDGE aliases at all here. If there is some command to enable it now I can't find it.
Same here it's not working in this build.
Try what I found in Bug #2 and see if that fixes yours, just curious.
