Here are some reminders I read on a Chinese radio seller's site:
the legitimate use of green and healthy. Walkie Talkie the Green public radio, can completely relieve your worries!
- Using rechargeable walkie-talkie for the first time, please charge for 16 hours.
- Turn off your computer before removing the battery.
- Please do not use hand to pick up the antenna, hold the antenna will affect the effective wireless intercom call range.
- Use the walkie-talkie, you should keep it vertical distance of 5.0 to 7.0 cm, and keep your face.
- Please try to use while driving handsfree speaker and the closing words.
- Keep your intercom televisions, computer monitors and other screen to maintain a distance greater than 10cm, to avoid being magnetized.
- The interphone Do things together with other metal-containing storage.
- Walkie-talkies may interfere with some hearing aids, with your hearing aid manufacturer to discuss alternatives.
- Try to place in the medical walkie-talkie off, so as not to affect the use of medical equipment.
- Do not use in airports and on aircraft. If so, prohibited driving the car to the side of the road and then.
- In potentially explosive areas must remain shut down, unless it is dedicated intercom dangerous areas (for example, Factory Mutual, CAS, or UL certified).
