Hi all,
First, I am new to the radioreference forum. I see there are three forums on digital voice, so I hope I chose the correct one
I have been doing some reading on DMR and dPMR and I have three of questions concerning DMR:
- I know there is DSD that should be able to decoce DMR, but is there an full open-source stack of DMR?
It would be nice to have the basic stack to write our own dPMR repeater for ham-radio use. Are there already projects for this?
- A know that DMR is TDMA-based so requires a SDR radio. However, if I have read correctly, a DMR repeater does not switch on/off the radio every 30 ms. It does have the concept of TDMA, but transmits continues two timeslots. If one timeslot is not used, it is transmitted anyway be it without content.
Is this correct?
Because if this is indeed the case, this would mean that one can build a DMR radio using the simular technologies like D-STAR repeaters: a modem-card (now doing C4FM instead of GMSK) and a FM transceiver with a "9k6" dataport.
- The ETSI specifications of DMR mention an option to run a repeater on a single frequency, using one timeslot to transmit and the other one to receive.
Does anybody know if this is actually used in practice.
For ham-radio use, this would be interesting for -say- 10 meter (to avoid having to use cavities) or the 4 meter band (which is only a couple of hunderd KHz).
Any thoughts?
73
kristoff - ON1ARF
Is this correct?
Any thoughts?
73
kristoff - ON1ARF
