I just recently purchased a travel trailer and I wanting some insight on mounting a Dual band antenna on the roof.I don't want to do any drilling it at all possible into the roof. I am thinking about getting a metal plate and caulking it to the roof or mounting the metal plate on top of the AC unit. Its a 2015 trailer so there is like no metal anywhere on top and I don't have a ladder mounted to the trailer either. I do plan to run the coax down the front or down the back and drill a hole up into the storage bay then route the coax under the bed to the radio. I will eventually put HF in the rig as well but vhf/uhf first.
So i am looking for any other suggestions or pictures of any Rv antenna installs.
I've owned travel trailers for nearly 45 years and installed various radio systems in them. These days, I'd consider one of the dual band (2M and 70CM I'm guessing in your case) antennas that does not require a ground plane and then attach it to a pole that is easily raised and lowered. One of the buddy poles would be perfect, but they can be pricey. Something to consider is one of the extendable poles used by window washers. They collapse down to 8 feet in length, but would extend well above the roof of the trailer. With a little ingenuity, you should be able to secure it to a side of the trailer, maybe using the awning struts right up against the outside wall of the trailer.
An RV buddy of mine uses a long pole like that for a flag pole. It's held up very well against some strong winds over the years. I see no reason it would not work for an antenna mast as well.
I have a 2M/70CM j-pole from Ed Fong that is inside a 5 ft piece of thin wall PVC pipe. Luckily, my fiver has a ladder on the back and I was able to fabricate a mount for the j-pole out of some 1x4 PVC stock that is clamped to the outside of the ladder. Loosen a couple of wingnuts and slide the j-pole up for use or down for travel.
If I was doing just 70CM and/or GMRS, I'd consider mounting an NMO in the center of a large aluminum pizza dish and fasten it down to the roof without penetrating the membrane. The Dicor caulk for membrane roofs is perfect for this kind of work. Route the cable down to a convenient entry point into the trailer and you're done. The pizza dish should be large enough to give at least a 6" ground plane in all directions. Larger would be better, but a 12" to 14" pizza dish would be very adequate. I have the NMO and antennas in stock so the only expense would be the pizza dish. I buy a fresh tube of the Dicor caulk every year or two anyway so I don't count that in the cost of installing an antenna.
There's lots of ways to do this.
