Kenwood TK7180/8180 Transmit Power
WatnNY
Knoxville, TN
How do I make the low power transmit higher than 5 watts? Do I need to open up the unit and delicately turn a screw or is it done in the technical side of internal programming?
Thank you all for your help.
Mike
BirkenVogt
BirkenVogt
Connect via a programming cable and under the programming menu where it says read and write there is also a test mode.
Put it in test mode and then you have access to all the low level settings. This is done in real time through the programming cable. Tx low power or something like that. There is a slider and some numbers. Slide it up while measuring output.
WatnNY
Knoxville, TN
Thank you so much for your help, BirkenVogt. The software had a warning about changing the parameters. Is there any real harm from changing the low power from 5 watts to say 20 watts?
Mike
BirkenVogt
BirkenVogt
The warning is so that you don't go in there and screw something up because the tuning settings are all essential to the operation of the radio and you can't set them back to default if you mess them up, they must be tuned individually.
Transmit power is sometimes a problem if you go too low (gets dirty) or too high (I don't think this is possible but going over rated power could damage the amp) but you are going for something in the middle which will be just fine.
WatnNY
Knoxville, TN
Thanks again, BirkenVogt. Do I have to do this for each individual channel, or is the setting for the radio itself? And lastly, I want to make sure I'm in the "test mode" you're speaking about, all I need to do is click on test mode, then low power transmit. There's nothing special I need to do?
And I owe you a huge cup of coffee for all your help! :cool:
Mike
BirkenVogt
BirkenVogt
The settings in test mode are global and cover all channels. Some of them have wideband and narrowband versions but I don't think tx power is one of them.
Then each channel has its high or low relative power setting but that just goes back to the amount you programmed in test mode but you knew that already.
WatnNY
Knoxville, TN
Thanks again BirkenVogt. I owe you a cup of coffee if I ever get to BirkenVogt! :cool:
Mike
