Carroll County Cutover to P25 is today
mikev10
If anyone is interested in picking up the Broadcastify coverage for the new Carroll County P25 system, I have the trunking codes.
mikev10
There are (9) Frequencies in the system:
851.1625
852.1375
852.3375
852.4250
852.4750
852.5875
852.9375
853.3375
852.4500
I will list public safety trunktracker codes in next post.
mikev10
Talkgroup Trunktracker codes
(A1) MAIN - 10301
(A2) FTAC - 10302
(A3) EMS-1 - 10305
(B3) EMS-2 - 10306
(A7) FG10 - 10308
(A8) FG11 - 10309
(A9) FG12 - 10310
(A10) FG13 - 10311
ANNC GROUP FOR 10'S - 10312
(A11) FG20 - 10313
(A12) FG21 - 10314
(A13) FG22 - 10315
(A14) FG23 - 10316
ANNC GROUP FOR 20'S - 10317
(B7) FG30 - 10318
(B8) FG31 - 10319
(B9) FG32 - 10320
(B10) FG33 - 10321
ANNC GROUP FOR 30'S - 10322
(B11) FG40 - 10323
(B12) FG41 - 10324
(B13) FG42 - 10325
(B14) FG43 - 10326
ANNC GROUP FOR 40'S - 10327
Law Enforcement
POL ANNOUNCEMENT - 10370
SHERIFF - 10349
G MSP OPS - 10359
WCPD - 10363
Engine4
Westminster, Maryland
When will the RR database be updated for P25?
And, what's the difference now with the changeover? Will my BCD396XT be compatible with it?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This will need to be submitted to the database team to update the entry. How long? No way to know for sure
Yes, as long as you can hear the new control channel, the 396XT should be able to trunk it (for now). The database has this as a Phase 2 system, so if / when that happens, you will need a Phase 2 scanner to trunk it. The 396XT won't do it. I suspect they will run in Phase 1 to shake out the system before they all migrate, but that's purely a WAG on my part.
However, as noted in another thread, there is the possibility that if you are in an outlying area, you may have a more difficut time hearing the system. There is a mandate (?FCC) that strongly recommends reducing the signal levels in areas that are not intended for coverage.
Engine4
Got it, thanks!
Amazingly, I was able to program in the info Mikev10 provided in a previous post. Seems to be working, however the audio leaves much to be desired.
troymail
Silent Key
Got it, thanks!
Welcome to (I suspect simulcast and) digital voice....
Hard for me to believe that Carroll County (and St. Mary's and Harford) is/are now ahead of Anne Arundel County in radio technology. :lol:
Congrats!
On the other hand, at least for now, Anne Arundel County is pretty clear with their analog trunk system so I'm not complaining.... ;)
mikev10
If someone could get the updates I provided added to the database that would be great. I'm already getting hounded by friends up there with Home Patrol scanners who need the information.
troymail
Silent Key
You can/should submit it. If you do, it will make the library updates from download starting Saturday (for GRE radios) and Monday (for Uniden)
fxdscon
¯\_(ツ)_/¯
Click on this link to submit your info to the database admins:
Submit Data to RadioReference
Your friends don't have to wait for the database to be updated to listen to the new system. They can use the info you have provided to create a favorites list and begin receiving that system right away.
Good to bad
Oh Boy Oh Boy !!!
Now Carroll County is as garbled and broken as Baltimore County on my radio.
mikev10
Thanks for the link, I went ahead and submitted what I've listed above.
W3DMV
Gettysburg, Pa
The old analog system was always easy to receive here in Gettysburg. Even
using a PSR-800 and stock antenna.
The new system is gonna be very difficult. No signal with the PSR-800 now and had
to resort to a 12 element/800 Mhz yagi antenna @ 30ft, fed with 1/2" hardline and
the control channel is only slightly above the noise..
Tried various combinations of receivers including three BCD-996t, and Icom IC-R7100
without success. Antennas used, discone, 6db coaxial stack, and a coat hanger.
Ran Pro96comm for about an hour using the PSR-800 and yagi. Please take the
info as very suspect because of the low level signal
System ID 66A
Tower ID 101 (T0101)
WACN BEE00
852.1375 D
852.3375 V
852.4250 A
852.4500 VD
852.4750 CC
852.5875 A
852.9375 A
I did not see two others posted above.
851.1625
853.3375
bwhite
Carroll County, MD
FreeScan P25 type
In FreeScan I see several choices related to P25, can anyone advise as to whether the correct choice is Mot Type II/P25 (prior so prob not this now), P25 Standard (Digital XT), or P25 One Freq Trunk (Digital XT). Thanx
mikev10
W3DMV.....
Those last (2) frequencies you didn't see are still over on the old analog system for some remaining traffic that is still being transitioned over. They will be brought over very soon.
mikev10
PS W3DMV.....
You may want to redirect your yagi towards the Bridgeport site on Rt 140 at the Carroll/Frederick line. See if that helps.
