TK-3402
thevfdguy
colorado springs, co
Does anyone know if the TK-3402 LMR is identical to the TK-3402 PROTALK Radio except for the PROTALK software? Is the TK-3402 PROTALK available with a 400-470 band split?
I see a lot of PROTALK radios for sale but nothing on the LMR version.
I've been working on this with someone else, and here's what we've figured out....
Electronically, they are the same. Same FCC certifications, all the part numbers I've looked at are the same, at least when comparing similar wattage models. The TK-x400 models appear to be the same electronically as the TK-x400 protalk models (2 watts). The TK-x402 models appear to be identical to the TK-x400 models with the only difference being in the RF board having to do with the 2 watt vs. 5 watt ouput.
The firmware is the same between the TK-x400 and the TK-x402 radios.
The original product release info for the x402 protalk radios mentions that they can be programmed using KPG-160DK.
So, the guy I was working with on this tried pusing the non-ProTalk firmware into a ProTalk radio and it took it, however it still says it's a "protalk" radio. So there is something. I haven't heard any more about this, and I don't have one of these radios myself or the time to work on it.
Seems like if all you want to do is take a ProTalk radio and program your own custom frequencies into them, it can be done using the KPG-160 software.
The non-ProTalk UHF radios are available in 450-520MHz versions AND a 400-470MHz version.
The ProTalk UHF model is advertised as having 90 channels preprogrammed between 451 and 470MHz. Looking up the FCC ID for the Protalk radio (ALH435002) shows it as being a 450-512MHz radio ONLY.
There isn't a 400-470MHz version that I've found. The physical internals of the RF portion of the radio would be different, so this isn't just a programming change.
thevfdguy
I wasn't aware that the PROTALK was a 2 watt radio. I am looking for 5 watt units. I would like to purchase new ones if I can locate a Kenwood dealer in Colorado springs. I would like to get some used TK-3180's but I need a couple of idiot proof units.
TK-3180's can be locked down pretty well in their programming. Disabling a lot of the functions would just leave on/off volume, channel select and PTT.
Benefit would be that you'd have a common radio platform, same batteries, accessories, etc.
If you get the non-protalk TK-3402's, they are 5 watt, and can be programmed.
If you are just looking for dirt simple radios, the used TK-390 UHF portables are running around $100 - $150 on e-Bay. Much more durable radio in my opinion.
