zzdiesel
Does this radio record?
It doesn't have a SD card either. Click on the link I posted and you can see it's features.Ok. Thanks. This is the first one I've saw with an SD card that doesn't record.
Does free scan work with the bct996p2, i was told no but want to see if anyone has any tricks to make free scan work with it if it does not
The FreeScan 2.18 Beta is just the .exe file.
You will need to install FreeScan 2.17. Then download the 2.18 Beta. Move the 2.18 Beta .exe file into the FreeScan 2.17 directory (wherever you installed it), and use the 2.18 Beta .exe
RodeoGeorge
The Freescan 2.18 download at the link I posted above contains an exe file that is the set-up executable that launches the setup wizard, and will install the complete 2.18 beta on your computer. I have never had 2.17 on this computer. The 2.18 installed and runs just fine without any trace of 2.17 needed. Using Win7 64 bit.
