WS1080 Battery Life
To answer the main question... Yes. Firmware 2.6 update addressed this
Version 2.6 - March 3, 2015
"Changed algorithm used for battery level icon.
New default voltages for NiMH icon thresholds" AND UPDATE for the EZscan application AT the same time 2.03 Includes:
Version 2.03 - March 3, 2015
Updated default battery indicator values to match new CPU firmware.
Corrected an issue when attempting to copy custom table values to all sites on P25 systems.
Added button on P25 system custom tables in insert the default Ch-Lo, Ch-Hi, and Offset values"
AND you also had to change the EZScan grid for the batteries too as it didn't automatically change the application form, just did the radio as we discussed in this forum post
http://forums.radioreference.com/gre-scanners/308958-ws1080-firmware-2-6-available-3-3-15-a.html
Poster MichealBhere reminded us to make sure the EZscan form for NiMh was changed too, mine was NOT even after the update to the radio, so instead of typing it all in? I knew the radio had the update, I simply downloaded the radio/SD card to the form....then it changed to the proper updated numbers. My battery life has been great lately for all of the ones I use from 2500 mAh to the 2700 PowerEX from Maha. 2700s went from 4:30pm till 5:00 AM straight after the update and had some power left over for the next day of about 20 minutes or so.
NiHh
14 bars 4.90
12 bars 4.80
10 bars 4.70
8 bars 4.60
6 bars 4.50
4 bars 4.40
2 bars 4.30
0 bars 4.20
Alert 4.18
