Feeding multiple scanners
Colton25
So what do you recommend I do with 2 scanners 1 radio and 1 antenna
All the scanners have BNC connectors so I just use patch cables. The transmitting radios have PL259s and have individual antennas with proper connectors.
Only the scanned are connected to the multicouplers.
N9JIG
Sheriff
Moderator
Far NW Valley
If the radio transmits then it gets it's own antenna, no easy way around that.
Scanners can share an antenna with each other using a multicoupler.
If the single antenna deal is written in stone and you HAVE to have a radio that transmits then then you are going to need antenna relays,that pretty much means a professional installation.
Colton25
What if I had one antenna for radios, and one for scanners, would that work? Can I transmit on the radios if they are all connected to the same antenna without harming the radios?
N9JIG
Sheriff
Moderator
Far NW Valley
Each transmitting radio should have its own antenna.
There is no easy way to share antennas between transmitters. That would require expensive and complicated equipment like antenna relays.
Colton25
Ok thanks, may I ask what you are using for the cable that connects your power supply to your powerpole?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Off-topic posts moved to Splitters, Filters and Multicouplers forum so as not to detract from Rich's impressive install thread.
