On the MOTOTRBO radios, the RSSI value that can be read on the display on the radio is not relative (as it is in the high-tier APX series of radios). It is calibrated in dbm (with reference to a 50 ohm load), so it should be very close between radios.
Checking a couple of portables (XPR6550 and XPR7550) with a service monitor showed the RSSI values, shown on the portables, to be within 1 to 2 db of actual signal level from the service monitor.
This makes sense, that these RSSI values would have to be calibrated, since RSSI values are used to set up roaming in an IP Site Connect network. If these RSSI values were 'relative', then there would never be a way of accurately setting up roaming.
John Rayfield, Jr.
Thanks fxsdcon.
Unfortunately I am requesting a little more info. Please re-read my post and you will sense that I have already read the wiki.
Basically I'm trying to find out how the TRBO Tech correlated RSSI to dbm.
Cheers
Doog
