XTS Fail 01/82 Question.
dixie729
Daviess Co., KY
Got a an XTS 2500 with the notorious fail message 01/82 on start up. I was re-programming some features and the CPS froze. I'm told it has to go to the depot for re-flashing. My question is, does re-flashing mess with the CPS Release Version I used to program it?
Kevin
Emergency Vehicle Installation Technician
robertpearsall
Edison, NJ
Try reloading to co-plug again that may fix problem if you have the one before you made changes load that one and see what happens I beleave depot will load the newest firmware
dixie729
Daviess Co., KY
Code-plug was a no go. It was on a crashed computer, I thought I had it backed up on my new computer but no...
Kevin
N4DES
Retired 0598 Czar ÆS Ø
South FL
Kevin
Yes it usually does. Depot typically reprograms the radio using the current CPS version unless you tell them otherwise. If your CPS subscription isn't up to date I would include a note with the radio requesting that they use a CPS version that you are currently using.
As a positive the radio will come back with the most recent Firmware so if you hadn't done an update in a while the radio will have the latest Host and DSP.
dixie729
Daviess Co., KY
Thanks KS4VT. I'm going to try to get a codeplug to see if it will take it. If not its off to the depot... Wouldn't happen to know a cost would you?
Kevin
