QwKiE
Will Windows 10 and Sentinel work together for HP1 and HP2 updates when Windows 10 is released July 29 2015?
I have not tried the serial driver as I have been using WiFi for control since Uniden released the firmware. I can say that the mass storage drivers used for programming are plug and play. I will give it a try in the next couple of days.
I cannot get the sentinel software to install for my bcd436hp, It says I need net framework 2.0 and 10 already is installed with net frame of some 4.xx
Any suggestions? Also how are you using WiFi for control and programming? For some reason I can't find any drivers for this scanner.
What about the serial drivers?
If you need .Net 2.0, type “Windows features” in the search bar and select Turn Windows features on or off (Control Panel). You can also access this through control panel. Check the box next to .Net Framework 3.5 (includes .NET 3.0 and 2.0).
For remote control, I use ProScan (ProScan). You can control a BCD536HP via WiFi or serial. You can control a BCD436HP via serial.
If the serial drivers are not plug and play, I'm guessing the Windows 7/8 Drivers from Uniden will work.
BCD436HP < UnidenMan4 < TWiki
BCD536HP < UnidenMan4 < TWiki
I just want to confirm, if I run into the OP's problem; I need to DISABLE Net 4.5 and make sure Net 3.5 (includes Net 2.0 and 3.0) is ENABLED?
Leave 4.5 enabled. Add the feature for .Net 3.5.
