Clearwaterpd goes p25 edacs no loinger monitorable
mitbr
Tampa Bay Florida
Clearwater pd goes p25 edacs they are no longer monitorable with a scanner. Sad day it was nice while it lasted.
Tim
kayn1n32008
ØÆSØ
Sector 001
The dispatcher said to switch to p25 mode.
Again, EDACS does not support P25 voice. Only Ageis and Provoice. Only way to 'go P25' is to stop using EDACS and go conventional or to APCO P25 trunk system.
Also P-25 IS monitor able IF it is not encrypted with most any digital scanner.
baayers
Pinellas County FL
I wonder if they switched over to the Pinellas county P25 system? If so the question would be encryption or no encryption? If no then we are still good.
Will be there in a few weeks so curious to see what is discovered.
mitbr
Tampa Bay Florida
Here is what I am presently hearing, on their edacs system I hear garbled noise on their west talkgroup it does not say it is enc.
RayAir
Hopefully not ADP. I don't know if the ADP algorithm will show up as "E" on a scanner.
rapidcharger
The land of broken calculators.
Huh? EDACS and P25 do not go together...
I'm wondering if the title should have a period in a key place.
"Clearwaterpd goes p25 edacs no loinger monitorable"
should read;
"Clearwaterpd goes p25. Edacs no loinger monitorable"
Now does it all make sense?! :D
I'm guessing Clearwater was on Edacs. Now they are using the race-to-wastiness of them all, P25. Just a guess.
mitbr
Tampa Bay Florida
should read;
I am hearing them on the same edacs freqs just garbled and the disp said switch to p25.
Can they use the same freqs and throw a switch I am puzzled.
mitbr
Tampa Bay Florida
The only thing I can think of is that they went provoice if they did when listening to the freq should I hear anything at all?
tampabaynews
Keeping your PIO busy
Tampa, FL
Clearwater has had plans to switch to P25 for some time with a separate system from Pinellas. I made a post a couple months ago where I heard a P25 control channel on one of the frequencies used for the EDACS system.
Harris makes EDACS and P25 and can provide an easy migration, which could be what they just did. What you should try is programming the frequencies as a P25 system. I can't try as I'm out of town until Friday.
And to clarify some wrong information... P25 is monitorable by digital scanners (just like Pinellas). Not a sad day unless they're using encryption.
Bolt21
Spark Chariot Driver
Punta Piñal
Phase 2 with encryption. Guess they solved their problem with people feeding their comms.
tampabaynews
Tampa, FL
It sounds like the damage was done a long time ago.
However, you're encouraged to send your comments to CPD via Facebook, Twitter, E-mail, USPS, or phone. Although a long shot, encryption can be turned off. Perhaps if they see this pissed a lot of people off it may decide otherwise.
They didn't even inform the media this was going to occur and I'm in the process of brewing a storm in that regard. Complete encryption is poor form for local government agencies for many reasons. Your average citizen isn't going to care so it's really up to us to complain... or do nothing.
SpectrumAnalyzer
Previously Banned Member
Banned
The Communications Monoliths Latest Cutting Edge Encryption Standards
Harris just closed a $500,000 million dollar deal with the Seminole Hardrock & Miccosukee Casinos with their latest "Unmonitorable by any known scanner technology" communications system.
Not to be undone Motorola just debuted a taxpayer funded $1.5 billion dollar per network law enforcement client only communications infrastructure that even they cant figure out.
