The RS 800 duckie is awesome, and you should have good results. I use the RS 800 Duckie, and it pulls in the SAFE-T like crazy. I get great results from all 3 INDY sites, as well as the Hendricks Simulcast, Shelby Simulcast, Boone Simulcast, Greenwood, Greenfield, Franklin, Mooresville sites very good, and the Hamilton County site pretty good, depending on weather. You shouldn't have too much multipath issues on IDPS as your far enough away that you should only get one of the multiple towers on the IDPS Simulcast. Not sure how well you will do if you try to get System 3 (Hamilton County) from Gfield. You would do even better if you had an pole mounted yagi antenna at about 30 feet up. Be aware that the SAFE-T is undergoing conversion to P25, and your area will be converting sometime around first of the year 2016 (Phase 3 of the 6 phases.) Speaking of, guys be ready for a lot of activity after July 4thish.....
