R
retiredmich
Guest
Was reading some info on the RS 668 scanner, what I show was that you have to use the Soft Ware to program it, edit, or add to it, Does that mean you can NOT manually program it ?
ratboy , for what it's worth, I have never used soft ware, don't know if I know how to use soft ware, to me soft ware is a hassle because something can go wrong with it. & manually programing a scanner is some times a challenge which I like. Happy Scanning.
If software programming scanners were such a hassle, people would be complaining about it constantly. You do realize that if in the rare instance "something goes wrong with it" it is easily found and fixed by visually inspecting the settings/options in the software in a matter of seconds, (and is often an error created by the user) where as if you make a mistake entering something by tapping out a long string of settings manually you are going to have to wade through each option one at a time and hope that you can find the problem? That is, if you can even remember where you are in the maze of menus at any given time.
Programming a complex scanner with anything more than a couple of freqs manually is like reading a map through one of those cardboard tubes the paper towels are rolled around. Once you find what you need you've lost all perspective because the rest of the information is out of your view.
