UV-5R Disable Transmit?
KC9VZV
For the life of me, I can't seem to figure out how to disable transmit for a few specific channels on the Baofeng UV-5R.
I have found a few different places on the Web that talk about how to do it but all of them either don't work for me or don't make sense how to do it.
I'm sure this question has been asked before on here but for the life of me, I can't find it! Any help would be appreciated. (I do have CHIRP software set up.)
KC9VZV
Change the Duplex setting to Off
Thanks! I thought I did that but turns out I accidentally set the Duplex mode to (none) instead of Off and that's why it wasn't working. Thanks again!
khaytsus
And if that doesn't work in the future on a different radio, what I had to do for one of mine is figure out the offset into ham freqs so at least I was transmitting into a legal area if I did accidentally do so... Assuming it'll let you offset that far. Luckily this radio did.... It would not disable transmit, but I could set offset to be -15mhz for 460mhz RX and RX on 445mhz for example.
nd5y
Wichita Falls, TX
In addition, I set the offset to all zeros.
All that does is make the transmit frequency the same as the receive frequency.
The only proper way to disable transmit is setting Duplex to Off for each channel that you don't want to transmit on and that can only be done with Chirp.
KC9VZV
Thanks guys. Yep, setting the Duplex to Off works for me.
dmg1969
Newport, PA
That's why I said "in addition". I had seen that advice on several websites when I was looking into the same issue. I am not into amateur radio, so I do not know about all of the various functions and settings of a HT.
