Well, there is a way you could do what you wish on your 436. It isn't the most efficient and would be a pain to maintain. Plus I would not do it on a bet and I'm offering this up as a way of accomplishing what you want.
Let's assume you need to monitor 6 sites on the state system. You could make 5 copies of the county system, for a total of 6 versions, each having their own unique FL and name.
FL 1 County System_Original
FL 2 State System (Site 1)
FL 3 County System_Copy 1
FL 4 State System (Site 2)
FL 5 County System_Copy 2
FL 6 State System (Site 3)
FL 7 County System_Copy 3
FL 8 State System (Site 4)
FL 9 County System_Copy 4
FL 10 State System (Site 5)
FL 11 County System_Copy 5
FL 12 State System (Site 6)
FL 13 County System_Copy 6
You'll see the pattern - the scanner monitors the county system, then goes to one of the state sites. It goes back to monitoring the county system (though it is a separate "clone"), then to the next state site. It goes on until all state sites were sampled.
If it was me, I'd either put up with the 6-10 state sites or get another scanner. I might cull the state list and because traffic on "Site 1" might also be on "Site 2".
Trust me, I have considered doing what you mention above or even combining the sites for both systems into a single system in the scanner. However, both are jimmy rigs and come with additional problems such as having to turn off and on large numbers of systems or quick keys each time, the requirment to duplicate any talkgroup or system changes numerous times over, etc. The GRE scanners do not have to be jimmy rigged to allow equal scan time regardless of the number of sites active.
I also monitor other systems at times as well (Denver, MARC, Aurora, Conventional). If I did what is mentioned above, the scanner would be spending an enormous amount of time on just two systems. This would necessitate also adding 5-10 systems for Denver and 5-10 systems for MARC and 5-10 systems for Aurora and 5-10 systems for conventional channels. At some point this would get absurd. I would have over 50 systems when only 6 are required in GRE scanners to do the same thing.
I was just thinking if priorities on talkgroups in one system were capable of being checked in-between the scanning of sites on another system this would solve this specific issue and would be a helpful feature.
I still run into additional programming issues with Uniden scanners beside the above: inability to assign talkgroups/conventional channels "across systems" into a single scan list (as GRE scanners can do), no sound notification when new unidentified talkgroups are received (a small thing which GRE scanners allow), and issues with patched talkgroup handling and the requirement to enter in an unknown "super group" to enable monitoring desired traffic on the non super group.
However, on topic, it would be nice to be able to sample priorities in one system between the scanning of sites in another system.
Shawn
