mercer county trunked system
trentbob
W3BUX- Bucks County, PA
... they do use it as a response ch.... I heard Hamilton fire told to use that TG the other night when responding to a wreck instead of SR-1... not sure why.
bailly2
a firefighter told me its a mutual aid talkgroup, used in remote areas like the turnpike
trentbob
... that makes sense... Hamilton was told to use countywide instead of SR-1 when responding to a wreck on 295 by the scenic overpass today...
Griggs
Hamilton NJ
The countywide TG is used primarily for any incidents on limited access roadways. It is designed to eliminate having to make "game-day decisions"on calls where resources from two different municipalities are being called to an incident. For example, I-295 at MM 65: units from Lawrence and Hamilton would typically respond. So instead of having to pick and choose a talk group, all units come together on one common TG, countywide....
trentbob
... good info Griggs... if I could ask you a Mercer question?... I have not heard the UHF Princeton Boro channel in a long time... I don't see a talkgroup on the Mercer County trunked system... are they dispatched now on the Princeton Twp 453.625 PL 103.5 or are they on the TRS and it's not listed?... thanks... Bob...
Griggs
Hamilton NJ
I believe everything was transitioned over to the township frequency with the merger, I am not 100% sure on that. I don't think they went to the P25 digital system, at least not that I am aware of...
mg3610
Princeton EMS uses the VHF repeater. Princeton Fire uses P25 on the North Region.
trentbob
... thanks Griggs... I was pretty sure they did merge but just wanted to make sure before I program a new radio...
