Hello,
I'm trying to program a used XTS 3000 model 1 bought used/ working from Canada. I read the radio, modified the code plug and successfully wrote to the radio with no errors. The soft keys work, channel 1 (conventional) transmits and receives as it should but the other 15 conventional channels have a steady tone, even the 2 that are Rx only (as if they are unprogrammed)? I have gone through all the channels in CPS and made sure all channels were set up the same as channel 1. there are no errors in the log, There is no secure options enabled. Any suggestions on what could be preventing channels 2-16 from being programmed?
Motorola XTS 3000 (model 1)
Model: H09KDC9PW5AN
Flash code: 549008-001C00-3
System package: H38
Max. channels: 48
CPS version: R05.03.00
~Sid
Model: H09KDC9PW5AN
System package: H38
Max. channels: 48
~Sid
