J-WeB
I have a Baofeng UV-5RA, and after initially programming it I was able to use the repeaters. Now after a week has passed, I'm no longer able to use the repeater. When I try to transmit and say my call sign, I get a response from the repeater as if I was just keying up the repeater. No one can hear what I'm saying. I discovered this problem when trying to get in on my local net one evening. I'm very confused. I've checked, double checked, and triple checked the repeater settings. I'm wondering if there is some setting or switch that turns the mic off or something. I'm a new ham, so I could just be making a novice mistake. Any help would be greatly appreciated.
Update:
I have two of these radios and both are having this problem. I've tested them on non repeater frequencies and they work just fine. The mic seems to transmit completely normal. Doing a bunch of internet searches I was able to find that these radios do have mic problems, but it seems like those forum posts didn't mention testing the radios on simplex. I'm so confused with this problem. If the mic works on simplex, shouldn't it work for a repeater?
Update:
