Motorola CPS Software
Kb2tue
Jamesburg, NJ
I have a HT1250 (UHF) and an HT1250 LS+ (VHF). My Professional Radio CPS (RO06-12-08) reads and writes to the UHF without issue, but will only read the VHF unit. Any ideas on what the issue might be and a solution. Note: I have a friend with the same software and he is able to read and write to the unit... both programs a configured the same...
IAmSixNine
Dallas, TX
Do you get an error message when trying to write the VHF?
Make sure your not on a pass port channel when trying to write back.
N1GTL
CT
Could the VHF unit already have been programmed with a newer version of CPS previously? R06.12.09 is the most current. If it was programmed with a newer version, you may be able to read the radio but not program it without the most up to date version.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Can you tell us EXACTLY what the error message is when you try to write to the LS+, please? That will usually give one of us enough accurate information to help answer your question. Without knowing what the error message is, any answers we might provide are guesses at best.
