Alright, here is a quick reply before work.
The closest cell phone tower is either less than a mile, or 5 miles. I need to verify. As for coax, I am open to suggestions. If someone wants to be so kind as to post a link to what the best would be, I would appreciate it. I have about a 20' run from the antenna to the drop amp. I will get on the roof and try the jumper on my next day off. It is aimed kind of halfway towards my 700/800/900 signal towers, and North to pick up Monmouth County. Again, the VHF is beyond amazing... UHF is better, and high band is crap.
To answer 737mech:
Where are those eight coax cables going to?
-3 PRO 163s, a PRO 652, PRO 2053, PRO 2039 & PRO 2050. Then one lead goes to another drop amp to 8 more scanners that I use sparingly.
Did you re check your coax for shorts?
-I did not inspect the entire length of cable, I simply assumed it would be in good shape as it came new in the box from Radio Shack. I did replace the factory crimp end on the antenna with a compression. Should I do the same on the other end?
Center conductor to shield?
-I believe I am okay on this, but a little elaboration would be tremendously appreciated.
What about programming in the scanner any attenuation set for any of the control channels?
-Checked the ATT, and it is NOT on for any of my control channels. The poor reception has been duplicated with every scanner on the amp, and when I did a direct run right to a handheld.
Anything get L/O by accident?
-Checked, and again I am good.
Proper trunking tables?
-Yes, these scanners were programmed by WIN500 and WIN97. I moved to this house about a year ago. My old location was much higher in town and I picked up everything. The programming of the scanners has NOT been touched since I moved.
What squelch setting?
-Squelch is right, it is right above the static threshold
Can you still hear with a rubber duck antenna only?
-Inside, no. Outside in my driveway, I can pick up the high bands with a handheld and rubber duck.
Other bands are working?
-VHF is amazing! NYFD on VHF and I am 60 miles away. All VHF on the next county north of me is killer. UHF is improved, but the distant 500 stuff is hard to pull in. As the frequencies go higher, my reception is poorer.
How's the marine band can you hear fishing boats?
-I have never tried, but I can check. The ocean is about 8 miles from my house.
Weather from NOAA?
-I can pick up four NOAA weather channels with the new antenna up high.
Military at Fort Dix?
-380 MHz trunked system comes in perfect.
