CPS version last used?
N4RMT
Is there any way to find out what version of CPS was used to program a radio? I'm getting a read error on an XTS2500 i picked up in a trade. Radio works fine, it just won't connect in CPS.
XTS3000
What error message is showing in the CPS?
If you need newer CPS, the CPS will pop up an error window saying a later version of CPS is needed.
N4RMT
Oh OK. I'm getting a "radio failed to acknowledge" message. It's a Kawamall cable, but ive never gotten a bad one before. I don't know. Maybe the radio needs a full charge. Maybe my COM port has gone bad.
XTS3000
Rather than just press the "Read Radio Icon", under file there is a read radio option, doing it this way you can double check what comport is being used. Maybe your selection of the comport is wrong. This has happened to me so many times because I use usb and serial cables and forget to reselect the proper port.
N4RMT
Try an OEM RKN4105 or 4106.
Yeah. I hope I do... The radio isn't even worth that much... Thanks for the suggestion, but I could just keep buying $18.00 cables until I get one that works and still come out way cheaper than that. I really don't think it's the cable just yet. I've never gotten a bad one from him yet.
MTS2000des
5B2_BEE00 Czar
In my experience, most of the aftermarket Astro 25 cables are complete crap. You might try to find someone local with an OEM cable. Bet your problems will magically disappear.
For a while, US Electronics on Ebay had OEM serial RKN4105s for $65 shipped. I was lucky to get one a few years ago. Never bricked a radio, never had a radio that would not read. Updated dozens of XTS radios firmware and reflashed many, never had one brick.
You get what you pay for.
sflmonitor
Sunny South Florida
May also be an old firmware issue. I've had XTS5000s with certain flash codes that had firmware versions 08 and older. Unfortunately I had to send those to the depot since I was unable to communicate at all.
XTS3000
I've had FPP and non-FPP xts5000's at firmware R03-R04 and never had a problem upgrading them to the latest R20.05.00.
Before firmware R03, there was no USB support, so only serial cables would work to bump their firmware up to current.
