Unable to read NX-240
BlueDevil
WA
I am unable to read or write my brand new/never programmed Kenwood NX-240 K portable radios. I am using the KPG-170D v1.21 software. The error I get upon trying to read the radio is "Ensure that the Model Name and Market Code are correctly entered."
I selected the proper model name and market code and have even tried all the other available options. I have confirmed that I am using the correct Com Port and I know the software is communicating with the radios because I can obtain the Transceiver Information from the radio using the software.
Any suggestions? Am I using the wrong software?
BlueDevil
WA
The software says the firmware version on the radio is V1.10.00
How do I know if that is too old/new for my software?
Do you know if it's a Version 1 radio or a Version 2 radio.
Version 2 radios should have a serial number that should start with or is higher than B54~ and the rear tag should say Ver. 2 on it.
For Version 1 radios, the latest firmware is 1.24 released in January of 2015. Version 1 radios cannot be upgraded to Version 2 firmware.
For Version 2 radios, the latest firmware is 2.01 released in April of 2015.
Version 1 radios will do analog and 6.25KHz NXDN. Version 2 radios will do analog and both 6.25KHz and 12.5KHz NXDN.
KPG-170 is the correct software for the NX-240/NX-340 radios. Version 2.0 is the latest version, released in February of 2015. It will program both Version 1 AND Version 2 radios.
Kenwood programming software of late has been backwards compatible with the older firmware. I doubt that is your issue.
The only time I've seen the issue you are describing is when the radio and software market types don't match.
So, the question there would be: Where did this radio come from? Did it come from a Kenwood dealer here in the USA, or did it come from somewhere else?
Software might be the issue, too. Did you purchase it from a Kenwood dealer or did you download it from some other source?
BlueDevil
WA
Ok. So that must be my problem? I have model NX-240V: K selected.
kd4efm
Florida
When you read the radio, it will not matter. It will be what it is. Where was the radio purchased from? No dealer name just their location. What does the label say on the box? It should show nx-240k. Does it have an fcc sticker on the battery area?
Evans Mitchell kd4efm
sent on my HTC M9
BlueDevil
WA
The radios I have were purchased off of eBay from a seller in Florida. They are brand new in the box and have never even been programmed (flashing red/orange LED). They have consecutive serial numbers (B3A04027-028). The model on the sticker says NX-240-K and has an FCC License Number. The serial numbers on the box match the radios.
BlueDevil
WA
I haven't been able to find the KPG-169D software. You think that's what I need even though my software says Model K and the Radio says Model K? Are my radios just too old based off the serial number?
No, those are version 1 radios and the software will support them. The issues is the "market" type. Since these radios were intended for a market outside the normal US commercial market, you'll need the correct hardware.
You could always drop a line to Kenwood tech support and see what they say.
Unfortunately this is one of the issues with purchasing radios off e-Bay. You don't always know exactly what you are getting. This should be a fairly easy solution, though. Finding the KPG software will be a bit more difficult.
BlueDevil
WA
I will continue looking for the KPG-169D software if that's what you think will program the radios. I will also try calling Kenwood.
BlueDevil
WA
I finally found the KPG-169D software and it worked perfectly!!
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Gentlemen, keep in mind that the software needed to program the radio can only be bought through Kenwood or its dealers.
Asking for it or offering it on the forums is forbidden.
