Earlier in the week I was listening to one of my scanners during my lunch break and a coworker came up and said "Didn't know you monitored a scanner". Got into a good conversation about scanning and he asked, "Do you know anything about DMR"?
Turns out he is trying to monitor a business down the block from his house that is a DMR Motorola Capacity Plus (TRBO) system.
He bought a LUITON DG-TD501 UHF in the hope of doing so. He has had no luck and asked if I could help in programming the radio.
I like learning new things so....
Before I go any further, a disclaimer, I told him, I would give it a try as long as he was only interested in monitoring and I would be disabling the transmitting function and would password the software/radio against changes. He is fine with that.
First step, I downloaded the driver and software (DG-TD501 Software & Driver). From my research, the software seems to copy of Hytera programming structure, if that helps.
Software is called "BFP-DH200F"
Software installed and I was able to read/write to the radio.
My first step was to enter the six system frequencies, each one under a individual channel. Was told that the "Color Code" is 1 and since the "Repeater Slot" is unknown to me, I programmed six channels with Slot 1 and six with Slot 2.
Again, transmitting function was disabled and no transmitting frequency was even entered as a fail safe.
As a test, I did enter one analog channel of a known system just to see know the radio receives.
Wrote back to the radio and, take it over and nothing on any of the DMR channels. The one analog channel receives great and the sound is great.
Based on the user manual, no programming manual available I could find, the LED will light green for RX and this is occurring on various channels.
What am I missing?
Thanks.
What am I missing?
Thanks.
