cwh51990
Anyone know what stadium security and patriot place security has changed their frequencies to
I have been informed that they've gone digital, no frequencies given and may be L8TR. Any info would be appreciated.
Gillette Stadium is now on MOTOTRBO Capacity plus on 464.4500 and 451.500, think there's a 3rd frequency in use. I work for security at Gillette they use the new 7550s and also the non-display radios. we also have the ability to send text messages via the radios, unsure if that uses a 3rd frequency or not or if one of the 2 are in use
They went to this new system so our PD can't monitor them cause they make the establishments call them for what would be police calls.
This will be their down fall.
I think they went to this system simply so they can better communicate and have more capabilities, or so they were led to believe by Moto salespeople. The PD being unable to monitor them is simply a little bit of collateral damage done. Motorola is heavily pushing MOTOTRBO for their non-public safety customers. The XPR7550 portables are nice. So is the new SLR5000 series of MOTOTRBO repeaters, designed to replace the aging XPR8400 series repeaters.
If they are not using any encryption, they could be monitored with software such as DSD+ and scanner with a discrimator tap feeding the raw discriminator audio into an audio input on a PC running DSD+. I have successfully listened to MOTOTRBO this way before. If ENC is in use then you're SOL.
Team Ops tells there establishments to contact them for any emergency (including 911 calls) instead of calling us that's an issue. Gonna be an issue soon
That's an operational issue, not a radio one. If they wanted, they could easily put one of their radios in the command post and/or dispatch.
