I know I am a true Apple fan boy, but I also have a Windows machine I use for radio stuff like my RadarBox, Pro96Com and others.
What I have is an HP Pavilion Elite e9180f I bought almost 6 years ago. At the time it was very impressive for a consumer grade machine, with a 1TB HDD, 9 GB of RAM and 64-bit Windows Vista powered by a 2.67 GHz i7 processor and with a full 1GB of v-Ram. While today, 6 years later, it seems pretty pedestrian at the time it was pretty much a top-end machine unless you were a gamer (which I am not). At the time it was the computer with the best specs I could find for under $1000.
It had some pretty rocky reviews that came out after I bought it but I have not had any problems with it other than the power supply going kaput a year or so ago. I added a USB3.0 card to use with my backup drive and I removed the wifi card to accommodate it, otherwise the hardware is as it came.
Within months I upgraded to Windows 7 Pro and that has worked just fine with everything I threw at it. For almost 6 years the machine has worked great, for most of that it was on 24/7 running an ATCS feed and the ADSB receiver. Most of the issues I had over the years were getting devices (programming cables etc) to work with the 64-bit OS. Now that 64-bit Windows is pretty much standard that isn't an issue much anymore.
Recently however I noticed the computer seemed slow. It may have been a relative thing since I replaced my Mac recently and that runs like a roadrunner being chased by the coyote. The RadarBox program took several minutes to load and other programs just seemed sluggish.
I considered getting a new computer, building one myself or seeing about upgrading the existing one. I decided that an SSD should speed things up and on the advice of the kid (who owns a computer consulting company) I bought a Samsung 850 Pro 1 TB SSD (Fry's $449). I figured if it didn't help much I could use it on a new-build.
After getting home I ran the included cloning program, which took a few hours to copy the contents of my old hard drive to the SSD. After that was done I opened the computer, and swapped out the drives. After I restarted the machine worked fine.
So far so good. It boots in seconds and is ready to go in less than 20 seconds. The RadarBox program, which would normally take 3 to 3.5 minutes to start did so in about 10-15 seconds.
I figure this computer will now last me another few years and when I replace it I will remove and retain the SSD. It was totally worth the upgrade! It ain't quite Mac-like but it works.
