Hello, I am still some what new to scanning , but been working hard building up my scan list in the scanner.
I have a Radio Shack Pro 651 and I use the ARC500 software with it, which seems to work well with each other.
I have just activated scan list #11 or tried to. Not long ago when I started up scan list 10 , which this was the first time to activate a double digit scan list , I learned that after Up loading from the computer to the scanner I usually have to press a few buttons to get all the scan list scanning with all numbers staying lit (not any blinking).
When I need to activate scan list #10 I just press #0 and that gives me Scan list #1 thru #10 all on the top row of numbers staying lite and scanning.
How do you start scan list #11 , the first double digit scan list on the second row ???? When it is lit and scanning do you actually see the #11 or is it represented by the #1 on the second row ????
Each time I try to enter the #11 all I get is #1 , as the first digit on the second row ????
It stays on as if it is scanning and so is the #1 scan list on the first row.
I have tried to go by the manual but the results doesnt seem to work to well, I am sure I am just not doing something right ????
Also what is the best way to get the Lighted screen to stay on longer ????
Can you adjust that with the software ?
TNX-----Tracker44
TNX-----Tracker44
