WaveBand batteries opinions
TDR-94
Has anyone purchased or used the Batteries from WaveBand Communications for the P7100/5100/700P series radios? Anyone have any opinion on the quality of them?
I know all those "type" batteries should be manufactured and "technically" perform the same,but in the real world that isn't always the case.
TDR-94
When it mentions in the description of these types of batteries:
"Guaranteed to maintain at least
80% of rated capacity for 18 months."
Does that mean that the battery will hold a charge of 80% of it's full rated capacity for 18 months after sitting around without use or does it mean the battery is capable of still being able to be charged to 80% of it's full rated capacity during normal cycling of it after 18 months of use?
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
It means that 18 months from now, the battery will still be able to hold 80 percent of its rated charge capacity.
It does NOT mean that if you charge the battery today, it will still be fully charged or even at 80 percent 18 months from now.
Batteries self discharge over time. It's a fact of life.
jackj
NW Ohio
You guys are complicating this more than you need to. It means that if you fully charge the battery today and then put it up on a shelf without using it, it will still retain 80% of it's charge after 18 months of storage. You will be able to recharge the battery to 100% of it's rated capacity. Another way of stating it would be that the battery will only loose 20% of it's charge after 18 months of storage.
TDR-94
I know some Nickel hydride based single cells are LSD and they can retain 80-90% of there rated capacity even after 5 years of sitting. I was just curious if these "packs" used lithium cells that had a lower self discharge rate than normal.
TDR-94
That's what I was hoping would be the case,but opinions obviously differ on what it means. I probably should contact them and ask.
