Most of the larger ham fests I have visited recently have had several "station master" style 800MHz antennas that have been removed from service.
With the specs for 800MHz coverage most agencies have, signal strength is generally not the problem, I have seen many installations with poor receive made worse by adding a gain type antenna. The front-end of most of the scanners is easily overloaded with out of band signals and multipath signals. A lower gain antenna (quarter wave) and possibly shielding from cell sites can often improve the signal much more than adding more gain.
As everybody above has said, the center whip is for low band (50 to 100MHz) reception only, it does nothing for VHF high and up.
Bruce
