I received my 1095 yesterday from Ham Station. Unfortunately, I am sending it back to Jeff. It seemed to work OK on VHF and 800 Mhz . However, on the UHF frequencies, especially LAPD, which is on 484 and 506 Mhz, the scanner was very deaf. Thought maybe I had the attenuator on, but no, it was off. Defintely was a problem in the frequency range. LA County Fire is on about 470 Mhz and the LA Sheriffs, about 483 Mhz. Signal strength was also much weaker than all my other scanners listed below. However, it was the UHF digital P25 LAPD (conventional), which is loud here in Cerritos from most of their sites throughout LA County, that was really quite deaf on the 1095.
I of course compared LAPD to my 536HP, 996P2, PRO-197, and WS1080. Signal strength was strong as usual. Definitely some issue with this particular 1095 unit).
I see that most everyone else seems to like the 1095 so far. But this particular unit is not working for me. That was obvious within a few hours using it. I will wait on buying the 1095 until I hear some other reports about the 450-500 Mhz range. Los Angeles has a ton of activity in that range.
