Not as easy as you might think. Read on.
First, I want to use a Uniden scanner because I want to utilize FTO mode. BUT... that brings about some challenges.
Second, I want to use a P25 capable scanner as some of the systems I listen to are P25 I not 2
But... (must have features)
1. For use in my truck.
2. Power on with vehicle, power off with vehicle, no intervention by me.
3. Not get stuck on a mass storage / serial menu when powering up from USB in vehicle (436HP has this problem)
4. (biggie), must be able to stay in FTO mode and survive power off power on (436HP does not)
5. Not corrupt the SD card (or not have an SD card)
436HP problems with above scenario:
1. only way to power on power off with truck is to use USB cable and pull batteries, with batteries in you
have to press the power button. But having no batteries and powering via usb always brings up mass
storage / serial menu requiring intervention (BAD, but could be fixed by Uniden in FW Update)
2. Goes back to scanning mode, won't stay in FTO mode (Bad, but could be fixed by Uniden in FW
update)
I'm not going to hold my breath that Uniden will make these changes, so I'm soliciting advice on other P25 I or I-II capable scanners that are well suited for mobile use. Really didn't want a full size scanner (or the cost), but have to consider all. Liked the idea of a portable scanner that could be used outside the truck
I believe my 536HP will stay in FTO mode after a power cycle. I am surprised that the 436HP does not. I know my needs are a little unique with FTO but I'm sure I'm not the only one who wanted to use a portable scanner in their car and not have to turn it on and off every time they go in. That's pretty darn annoying.
My other choice is to just throw my RS Pro 106 in there and give up on the FTO. Only problem is there is so much dispatch on that particular frequency I could see it becoming annoying. I really wanted to limit to my FTO settings.
Ideas / experiences - Thanks for your help.
Roveer
update)
Roveer
